Samsung Gear S2 Battery Replacement
    1. Samsung Gear S2 Battery Replacement, Watch Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement, Watch Strap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the watch over so that the face is down.
      • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
      • Remember to turn off the watch to avoid being shocked.
    2. Samsung Gear S2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your finger, push forward on the release while pulling up on the strap.
      • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    3. Samsung Gear S2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Repeat the procedure from step 2 for the other strap.
    1. Samsung Gear S2 Battery Replacement, Back: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement, Back: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
      • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
    1. Samsung Gear S2 Battery Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
    2. Samsung Gear S2 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear S2 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear S2 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a spudger, pry up the three cables.
    3. Samsung Gear S2 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the flat end of a spudger, pry up the motherboard.
      • Make sure the cable is fed through the hole to avoid damaging it.
      • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
    1. Samsung Gear S2 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using tweezers, lift the battery casing.
      • Make sure the cables are fed through their gaps to avoid damaging them.
    2. Samsung Gear S2 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
      • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
crwdns2935229:0103crwdne2935229:0
Jacob Baldwin
crwdns2935283:002/20/17crwdne2935283:0
3.459 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G3, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S2-G3, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S2G3
crwdns2935297:034crwdne2935297:0
crwdns2947412:039crwdne2947412:0
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
A reference to the battery part number would be great.
Harold Turner - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 176
crwdns2942667:0crwdne2942667:0 162,261
