crwdns2959928:0crwdne2959928:0 ↓If the heart rate monitor on the watch no longer detects your heart rate, then replacing the back may fix it.
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Using your finger, push forward on the release while pulling up on the strap.
Repeat the procedure from step 2 for the other strap.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
And where do you get the new replacement back? And does it just snap back on?
shawntravis76 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
