Samsung Gear S Home Button Assembly Replacement
  1. Samsung Gear S Home Button Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear S Home Button Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear S Home Button Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Home Button Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S Home Button Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
    is it a good idea to apply some heat first?
    ian stapleton - crwdns2934203:0crwdne2934203:0
    Do we need to apply some heat?
    Ousmane Sokona -
    I found the use of a razor blade was very helpful. Very thin and I was able to lift the edge.
    oneothefewproud - crwdns2934203:0crwdne2934203:0
    I would assume a small amount of heat would do wonders here...
    Gary Bartholin - crwdns2934203:0crwdne2934203:0
    DO NOT USE A RAZOR BLADE! It instantly shattered my screen, right from the start!
    It is double sided tape, around the entire perimeter, and across the middle, upside down U fashion.
    You can see the glue remnants in Step 3’s photo. Heat it first, even with a blow dryer, as I did not.
    It *may* work with an Exacto blade, but not a regular razor blade, given my broken display.
    On top of that, the corner shown in the photo is not the corner you want a blade near, as it cut my wiring to the display!
    Use the top left corner, away from the cabling.
    The notes don’t tell you that you need to have an adhesive to reconnect the display, until the very end.
    But hey, they’ll sell you more parts if you don’t follow my advice.
    Brian Kinney - crwdns2934203:0crwdne2934203:0
    You must have put the razor blade to far in because I used a single blade/ not the double side blade and it worked great and used the same adhesive by heating it up with a hair dryer.
    James fletcher - crwdns2934203:0crwdne2934203:0
    Apply heat dont attempt to do this with out heat
    Christaphor Henrie - crwdns2934203:0crwdne2934203:0
    ни в коем случае не отклеивайте экран, если только но не разбит! просто нанесите ушной палочкой изопропиловый спирт на обратную часть металлической рамки и просто отсоедините заднюю крышку. не трогайте экран!!!
    Alexandr Tarasov - crwdns2934203:0crwdne2934203:0
  3. Samsung Gear S Home Button Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
    The metal rim has to bend away from the motherboard in order for this to come out. Use a guitar pick.
  4. Samsung Gear S Home Button Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Home Button Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Home Button Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the watch should be in three separate pieces.
    Where does that piece to the left coming from?
    Ousmane Sokona - crwdns2934203:0crwdne2934203:0
    After separating into three separate pieces what is the next move in order that this device will be functional again.
    Odnalor - crwdns2934203:0crwdne2934203:0
    After the three pieces were already separated what will be the the next step or move in order to let this watch functional again.
  7. Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the home ribbon connector attached to the wrist side (side that faces the user when wearing it) of the motherboard assembly.
    • Locate the home ribbon assembly attached to the screen side of the motherboard assembly.
  8. Samsung Gear S Home Button Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to gently pry up on the home ribbon connector.
  9. Samsung Gear S Home Button Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pry up the home ribbon assembly.
Luis Franco
crwdns2935283:009/03/15crwdne2935283:0
1,076 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-1, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 12-1, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S12G1
where can i buy the home buton?
Hanna Iskandar - crwdns2934203:0crwdne2934203:0
I am in search of the SM-R750v Housing Back Cover, any suggestions
Rita Arnold - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 5,242
