This guide shows how to remove the display of the watch from the rest of the watch.
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
is it a good idea to apply some heat first?
Do we need to apply some heat?
I found the use of a razor blade was very helpful. Very thin and I was able to lift the edge.
I would assume a small amount of heat would do wonders here...
DO NOT USE A RAZOR BLADE! It instantly shattered my screen, right from the start!
It is double sided tape, around the entire perimeter, and across the middle, upside down U fashion.
You can see the glue remnants in Step 3’s photo. Heat it first, even with a blow dryer, as I did not.
It *may* work with an Exacto blade, but not a regular razor blade, given my broken display.
On top of that, the corner shown in the photo is not the corner you want a blade near, as it cut my wiring to the display!
Use the top left corner, away from the cabling.
The notes don’t tell you that you need to have an adhesive to reconnect the display, until the very end.
But hey, they’ll sell you more parts if you don’t follow my advice.
You must have put the razor blade to far in because I used a single blade/ not the double side blade and it worked great and used the same adhesive by heating it up with a hair dryer.
Apply heat dont attempt to do this with out heat
ни в коем случае не отклеивайте экран, если только но не разбит! просто нанесите ушной палочкой изопропиловый спирт на обратную часть металлической рамки и просто отсоедините заднюю крышку. не трогайте экран!!!
Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
The metal rim has to bend away from the motherboard in order for this to come out. Use a guitar pick.
Locate the ribbon assembly attaching the display to the motherboard.
Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
Now the watch should be in three separate pieces.
Where does that piece to the left coming from?
After separating into three separate pieces what is the next move in order that this device will be functional again.
After the three pieces were already separated what will be the the next step or move in order to let this watch functional again.
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
crwdns2935229:019crwdne2935229:0
crwdns2947412:016crwdne2947412:0
Where can i get the LCD for Gear S
my screen flashing light and show on screen lines
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
My watch is doing the same thing. Did you get a fix for it?
There are flashing yellow lights on the screen, could I fix that?
how much is a kit.
Were can I buy the display ?
Where can i buy the lcd ?
what kind of adhesive is best to reattach the screen to the watch?
did anyone find out where to get the screen???
How much buying lcd Samsung gear s
When I turn my gear s on it says rebooting then screen goes black , that is all I can get watch to do, is there a fix for this?
Hi. I have this watch for 5 years now and I'm so happy with it. Unfortunately the wrist strap is almost broken. Where can I get new one?
I need an lcd screen where can I purchase two.
I have two gear solo watches that need replacements.
El mio lo usas funciona bien, derrepente la pantalla empieza a fallar como si alguien la estuviera presionando o usando y tiene vida propia hasta que decide funcionar, es una lastima porque es un reloj especial, cuando se le pasa la falla puede trabajar bien por tiempo prolongado, alguien sabe que puede ser?
where can i get the ahesive to glue it back together?
