Samsung Gear S Battery/ Motherboard Replacement
  1. Samsung Gear S Battery/ Motherboard Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear S Battery/ Motherboard Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear S Battery/ Motherboard Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
    is it a good idea to apply some heat first?
    ian stapleton - crwdns2934203:0crwdne2934203:0
    Do we need to apply some heat?
    Ousmane Sokona -
    I found the use of a razor blade was very helpful. Very thin and I was able to lift the edge.
    oneothefewproud - crwdns2934203:0crwdne2934203:0
    I would assume a small amount of heat would do wonders here...
    Gary Bartholin - crwdns2934203:0crwdne2934203:0
    DO NOT USE A RAZOR BLADE! It instantly shattered my screen, right from the start!
    It is double sided tape, around the entire perimeter, and across the middle, upside down U fashion.
    You can see the glue remnants in Step 3’s photo. Heat it first, even with a blow dryer, as I did not.
    It *may* work with an Exacto blade, but not a regular razor blade, given my broken display.
    On top of that, the corner shown in the photo is not the corner you want a blade near, as it cut my wiring to the display!
    Use the top left corner, away from the cabling.
    The notes don’t tell you that you need to have an adhesive to reconnect the display, until the very end.
    But hey, they’ll sell you more parts if you don’t follow my advice.
    Brian Kinney - crwdns2934203:0crwdne2934203:0
    You must have put the razor blade to far in because I used a single blade/ not the double side blade and it worked great and used the same adhesive by heating it up with a hair dryer.
    James fletcher - crwdns2934203:0crwdne2934203:0
    Apply heat dont attempt to do this with out heat
    Christaphor Henrie - crwdns2934203:0crwdne2934203:0
    ни в коем случае не отклеивайте экран, если только но не разбит! просто нанесите ушной палочкой изопропиловый спирт на обратную часть металлической рамки и просто отсоедините заднюю крышку. не трогайте экран!!!
    Alexandr Tarasov - crwdns2934203:0crwdne2934203:0
  3. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
    The metal rim has to bend away from the motherboard in order for this to come out. Use a guitar pick.
  4. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the watch should be in three separate pieces.
    Where does that piece to the left coming from?
    Ousmane Sokona - crwdns2934203:0crwdne2934203:0
    After separating into three separate pieces what is the next move in order that this device will be functional again.
    Odnalor - crwdns2934203:0crwdne2934203:0
    After the three pieces were already separated what will be the the next step or move in order to let this watch functional again.
  7. Samsung Gear S Battery/ Motherboard Replacement, Battery/ Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the tabs on the motherboard and unclasp them.
  8. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spugder to gently pry upwards on the motherboard.
    • If you keep the battery attached to the upper half of the motherboard, you will have to gently pry upwards on both the battery and the motherboard.
  9. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the motherboard and the battery are removed, disconnect the battery at the connector.
  10. Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S Battery/ Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry upward on the clasp connecting the battery to the motherboard.
    Don't you have to use adhesive seal at the end???
    Jack Moskovita - crwdns2934203:0crwdne2934203:0
crwdns2935229:036crwdne2935229:0
Luis Franco
crwdns2935283:009/03/15crwdne2935283:0
1.076 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-1, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 12-1, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S12G1
crwdns2947412:017crwdne2947412:0
Thanks for the comprehensive guide! Where can one purchase a Gear S compatible battery?
JG - crwdns2934203:0crwdne2934203:0
Hi, did you found where to buy it?
Simone -
HI , How to by a battery?
Luigi -
I'm looking for a replacement battery.
jhdownes - crwdns2934203:0crwdne2934203:0
Thanks for the info, the adhesive holding the lens is tough. I need a replacement for the green, white and gold circuit board at the bottom of the watch back. see the left image in step 6 near the bottom. It is for charging. One of my gold contacts is burned or broken off. Does anyone know where to get the part or a dead watch I can take it from?
John Weir - crwdns2934203:0crwdne2934203:0
This site keeps deleting my link as spam. Very, very dumb. Do search on ebay for:
Charging Connector For Samsung Galaxy SM-R380 Gear 2
It is 7 bucks.
Andrew Vogtman -
Hi,
Look here please
Neue Original Ladeladestecker Für Samsung Galaxy R750 SM-R750 R750A SM-R750A R750B SM-R750B R750D SM-R750D Getriebe S 3G
http://s.aliexpress.com/vMBNzQV7
(from AliExpress Android)
Peter Longerich - crwdns2934203:0crwdne2934203:0
Hi all,
As my battery is showing signs of weakness (drains quickly up to 1 point/minute) I'm thinking about changing battery.
Ordered one here :
https://www.aliexpress.com/snapshot/0.ht...
Selected it as (it seems same mensurations) but more powerful.
A gambling as I'm not sure it will fit the genuine one. But worth to try due to price.
Battery was delivered without clasp . Can I remove this from the battery in the watch and use it for the new one ?
Thank you for your advice and help.
JF ELIES - crwdns2934203:0crwdne2934203:0
Here is a link to a brand new aftermarket replacement battery that includes the needed tools and has a 1 year replacement warranty!
Battery for Samsung Galaxy Gear S
michaelf33707 - crwdns2934203:0crwdne2934203:0
Hi I am looking for a battery. Where can get the battery?
tonysarker22 - crwdns2934203:0crwdne2934203:0
Where can I purchase an original back housing for this watch
Patrick Schneider - crwdns2934203:0crwdne2934203:0
is the battery of samsung gear s available here in the philippines.?
romeo del rosario - crwdns2934203:0crwdne2934203:0
Hi! I replaced the battery but it still doesn't turn on. I charged it all night, still nothing. What could it be? 😑
Rosalina - crwdns2934203:0crwdne2934203:0
Some important details left out?
Don't you have to use adhesive seal at the end??? And shouldn't you use heat to loosen the adhesive in the beginning???
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 32,474
