Samsung Gear Fit Screen Replacement
  1. Samsung Gear Fit Screen Replacement, Watch Band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear Fit Screen Replacement, Watch Band: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Screen Replacement, Screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear Fit Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear Fit Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear Fit Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear Fit Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear Fit Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear Fit Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear Fit Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently peel the screen assembly up and away from the device using tweezers.
    gear fit 2 screen assembly is very expensive at the moment at 135 USD + 10USD shipping… looks like you are buying a whole new unit, ridiculous… i am planning to buy a new GF2 and have my defective GF2 to be source of spare parts in the future ( battery, hear rate sensor, circuit board, etc..) or maybe wait some time till prices go down.
    ray floyd - crwdns2934203:0crwdne2934203:0
crwdns2935229:017crwdne2935229:0
Nathan Powell
crwdns2935283:004/24/14crwdne2935283:0
1 577 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-49, Amido Spring 2014 crwdns2935289:0Cal Poly, Team 11-49, Amido Spring 2014crwdne2935289:0
CPSU-AMIDO-S14S11G49
crwdns2947412:028crwdne2947412:0
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - crwdns2934203:0crwdne2934203:0
Where can you buy replacement screen?
Yele Olaniyi - crwdns2934203:0crwdne2934203:0
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - crwdns2934203:0crwdne2934203:0
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - crwdns2934203:0crwdne2934203:0
Does anyone know where to get the replacement screen?
MrGratts - crwdns2934203:0crwdne2934203:0
Where to find the replacement screen?
Jaime Ramos -
Ok Kudus to the Author! I was able to purchase a screen off of ebay for 40 bucks, followed your instructions and have my watch back! Thank you
Lynn Fox - crwdns2934203:0crwdne2934203:0
Where did you find the screen/digitizer?
Anthony Zuniga -
Why would you get a screen for 40 Bucks?? I found a used Gear fit in better condition then mine and was 6 dollars cheaper!
victorpho.kyin -
IFIXIT is very nice, but where can I buy the spare parts?
Bernhard Schmal - crwdns2934203:0crwdne2934203:0
hi, where i can buy screen gear fit?
Iwish Warfly - crwdns2934203:0crwdne2934203:0
Where can you buy the screen/glass? No one seems to sell it.
S Ramzey - crwdns2934203:0crwdne2934203:0
How to reassemble? What kind of adhesive should I use?
my activity screens are blank...says "unable to load data..tap to retry" nothing after I tap.
jdeiboldtsr - crwdns2934203:0crwdne2934203:0
need screen for samsung gear fit 2 black ..my screen crashed for some reason !!! can you let me know where i can order that ?
Shashank Dalal - crwdns2934203:0crwdne2934203:0
I need to buy the screen also anyone know the site to buy it on
Hale - crwdns2934203:0crwdne2934203:0
I need a samsung gear fit screen ...how can I?
Paulchambers@hpeprint - crwdns2934203:0crwdne2934203:0
Do you have a contact number please?
would this work with gear fit 2 watch??
dontae.christianson - crwdns2934203:0crwdne2934203:0
No, the Gear Fit 2 is disassembled via 4 screws on the back of the device under small four rubber caps. I learned the hard way
tankerred22 -
Hello,
Your best bet is Ebay. I found one for around $35.00, but there are preowened gear fit 2 for cheaper than that. I guess it would for sure be your call if you would like to fit it or not.
Flor Bounhas - crwdns2934203:0crwdne2934203:0
Has anyone found out where you can purchase a screen at?
Lavella Coffey - crwdns2934203:0crwdne2934203:0
I think my Gear Fits screen wasnt working cuz upon opening it, I noticed large amounts of cocaine residue.
Josh Grosskreutz - crwdns2934203:0crwdne2934203:0
You guys can get the screen from joesge.com. Also, there are screws hidden on the bottom. This is an alternate way of opening it, but will require a Philips Head Screwdriver.
John Clark - crwdns2934203:0crwdne2934203:0
but how to you know how much it costs
AIDEN MONSEN - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 53,844
