Place your thumbs on the ends of the screen.
Push the watch outward while pulling the band away from the watch.
Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Gently pry the screen loose using a plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers as a lever, pry the inner assembly out of the external casing.
This will be harder than removing the screen. Moderate force may be required.
Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
Gently peel the screen assembly up and away from the device using tweezers.
crwdns2935229:017crwdne2935229:0
crwdns2947412:028crwdne2947412:0
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can you buy replacement screen?
Yele Olaniyi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Does anyone know where to get the replacement screen?
MrGratts - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
