Getting to the battery requires disassembling the entire device, but the battery itself is easy to remove.
Place your thumbs on the ends of the screen.
Push the watch outward while pulling the band away from the watch.
Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Gently pry the screen loose using a plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers as a lever, pry the inner assembly out of the external casing.
This will be harder than removing the screen. Moderate force may be required.
Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
Gently peel the screen assembly up and away from the device using tweezers.
gear fit 2 screen assembly is very expensive at the moment at 135 USD + 10USD shipping… looks like you are buying a whole new unit, ridiculous… i am planning to buy a new GF2 and have my defective GF2 to be source of spare parts in the future ( battery, hear rate sensor, circuit board, etc..) or maybe wait some time till prices go down.
Three ribbon cables hold the motherboard to the rest of the assembly.
The battery cable in the front.
And two on the side.
Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
The motherboard is a segmented three piece construction.
Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
The motherboard should now be removable from the assembly.
Use tweezers to lightly pry, lift, and remove the board by its middle section.
With the motherboard removed, the battery is exposed.
A small metal strut protects the battery.
Remove the small metal strut by prying it out of both sides of the enclosure.
I look at not working changer but battery broken see here new watch samsung galaxy fit e.
I can tell help you
Remove the battery by pulling on the pull tab.
Don't be afraid to use force, the battery is tightly packed into the plastic enclosure.
To reassemble your device, follow these instructions in reverse order. Make sure that the ribbon cable connecting the battery is firmly attached; Don't be afraid to use some force.
crwdns2935229:037crwdne2935229:0
crwdns2947412:010crwdne2947412:0
Bgdhdhdhxhzjxjchf
Gdkysgkdgkdgxgmzg
Anyone know where I can find replacement parts for the charging terminals? One of the 5 fell out and I can't seem to find this simple piece anywhere.
Where can I purchase a replacement battery?
Where i can purchase a replacement battery in india?
What do I use to reseal the device? Glue? Lock tite?
Where can I buy a replacement battery?
I'm also wanting to find out where one can purchase a replacement battery. What kind is it? No point in removing it otherwise.
How much would this repair cost at a fixit store?
Is there a replacement battery for the samsung fit 2???
