If your display is failing, has distorted color problems, or is cracked, and you'd like to replace it then follow these step by step instructions. This requires close attention of the display and can be somewhat difficult with a rating of 5 out of 10 but should only take about 15 minutes or less if instructions are followed properly. Be careful because it'e possible to damage the case, and display.
Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
The pin is located, and marked on the picture.
Pull up on the tab that says, “Pull”, the battery will lift straight out.
Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
Place the plastic opening tool underneath the motherboard at this location. Gently pry the motherboard away from the front cover. It should pop off and be free from the cover.
Use the spudger and apply pressure to the back of the AMOLED display.
Once part of the display begins detaching from the front cover, place the spduger in between the display and the front cover.
Use the spudger to scrape off the adhesive located on the bottom side of the display, attaching the display to the front cover.
After the adhesive has been removed, apply pressure with the spudger to the back of the AMOLED display; the display should pop right out.
crwdns2935229:05crwdne2935229:0
