Samsung Galaxy Z Flip Top Glass Replacement
  1. Samsung Galaxy Z Flip Top Glass Replacement, Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your phone before you begin disassembly.
    • Open up the phone and set it face down on your surface.
    • Make sure your surface is clean and free of debris, as it may damage your screen.
  2. Samsung Galaxy Z Flip Top Glass Replacement, Heating the back glass.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the left edge of the phone for one minute.
    • Alternatively, you could use a hairdryer, heat gun or heating mat to melt the adhesive.
    • Be careful while using a heat gun or hairdryer, as you may damage the battery or screen.
  3. Samsung Galaxy Z Flip Top Glass Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Z Flip Top Glass Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Z Flip Top Glass Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the glass.
    • If your glass is badly cracked, you may use clear packaging tape to cover the cracked glass. This will allow the suction cup to adhere to the glass.
    • Push down on the metal part on the hinge while pulling up on the glass until the glass begins to separate from the frame.
    • Insert an opening pick into the gap between the glass and the frame.
  4. Samsung Galaxy Z Flip Top Glass Replacement, Begin to slice the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin sliding the pick down to the corner of the phone to slice the adhesive
    • Do not insert your pick more than a quarter of the way through, as you may damage internal components in the phone.
  5. Samsung Galaxy Z Flip Top Glass Replacement, Slice around the perimeter of the phone: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Z Flip Top Glass Replacement, Slice around the perimeter of the phone: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Z Flip Top Glass Replacement, Slice around the perimeter of the phone: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat previous heating instructions for each side of the phone.
    • Leave an opening pick in each corner as you cut the adhesive around the phone.
  6. Samsung Galaxy Z Flip Top Glass Replacement, Lift off the glass: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the rear glass of the phone to from the far left side of the phone to risk damaging the ribbon cable.
  7. Samsung Galaxy Z Flip Top Glass Replacement, Disconnecting the ribbon cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Z Flip Top Glass Replacement, Disconnecting the ribbon cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Uspudger to remove the plastic bracket covering the connector.
    • Use a spudger to disconnect the ribbon cable from the board.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
Luke Mcalel
crwdns2935283:007/19/20crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 126
crwdns2942667:0crwdne2942667:0 2,875
