Samsung Galaxy View Battery Replacement
    1. Samsung Galaxy View Battery Replacement, Kickstand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
    2. Samsung Galaxy View Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
    1. Samsung Galaxy View Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy View Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Check the device is completely turned off.
      • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
    2. Samsung Galaxy View Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
    3. Samsung Galaxy View Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
      • Insert the metal spudger within the opening.
      • Move the metal spudger down the seam, prying the back panel open as you go.
      • Once a large enough opening is made, pry the entire back panel off with your hand.
      • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
    4. Samsung Galaxy View Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
    5. Samsung Galaxy View Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy View Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
      • Remove the battery from the device.
crwdns2935229:040crwdne2935229:0
Roger Pena
crwdns2935283:010/06/16crwdne2935283:0
1 141 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-5, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 4-5, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S4G5
crwdns2947412:029crwdne2947412:0
I’m not sure if it’s the battery or the cord
Swheet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What size is the battery that fits into the SAMSUNG TAB VIEW?
Ricky Lee Lidel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank You, Sooo much. This guide is a true money and time saver. Worked like a gem .
Mike Rowe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Sue ELLEN R FONTENOT - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I find battery replacement for galaxy view
Greg Dover - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 28,140
