For the Samsung Galaxy TabPro S, model SM-W700NZKAXAR, this procedure is necessary so that there are no safety concerns with a cracked or strained screen. Also, the quality of the screen should be upheld in a high standard. Thus, knowledge in repairing of the screen is advantageous.
Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
Attach the small suction cup near the edge of the screen.
Pry in between the screen and the frame with a plastic spudger.
Pull up with the suction cup while prying and the screen should begin gently disconnecting.
Use the spudger on all edges of the tablet between the screen and the frame.
The screen should release.
Disconnect the thick cable from the motherboard
Disconnect the golden cable from the motherboard
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
