Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Reposition the bottom-left coaxial cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Reposition the bottom-left coaxial cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Reposition the bottom-left coaxial cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the bottom-left coaxial cables away from the frame, making sure the cables are completely unthreaded from the frame.
  2. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the antenna board's interconnect cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the antenna board's interconnect cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the antenna board's interconnect cable: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the antenna board's interconnect cable secured to the antenna board.
    • Use tweezers, or your fingers, to remove the cable.
  3. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Unfasten the antenna board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Unfasten the antenna board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 2 mm screw securing the antenna board to the frame.
  4. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the antenna board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the antenna board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the antenna board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger into a gap between the antenna board and the frame.
    • Pry up with the spudger to separate the antenna board from the frame.
    • Remove the antenna board.
  5. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Heat the left edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The bottom-left loudspeaker's connector is secured to the frame by adhesive; use heat to avoid tearing the connector.
    • Apply a heated iOpener to the left edge of the device for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  6. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Separate the connector's adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Separate the connector's adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the bottom-left loudspeaker's copper connector pads and the frame.
    • Pry up while slicing the adhesive to separate the pad from the frame.
  7. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slice with the opening pick along the bottom of the connector's cable to completely separate it from the frame.
  8. Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Bottom-Left Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and separate the loudspeaker from the frame.
    • Remove the loudspeaker.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
168.310 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.019crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 9
