Samsung Galaxy Tab S7 Plus Antenna Board Replacement
  1. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Heat the bottom edge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Screen removal information: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Screen removal information: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Screen removal information: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of the display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Heat the right edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the device to loosen the adhesive underneath.
  6. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom-right corner adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom-right corner adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom-right corner adhesive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the right adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the right adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the right adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Heat the top edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the device to loosen the adhesive underneath.
  9. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top-right corner adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top-right corner adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top-right corner adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the opening pick around the top-right corner of the device.
  10. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Heat the left edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top-left corner adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top-left corner adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the top-left corner adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the opening pick around the top-left corner of the device.
  13. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the left adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the left adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the left adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom-left corner adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom-left corner adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Separate the bottom-left corner adhesive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the top of the device facing you, pull the screen up and away from you like you're opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Disconnect the display cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Disconnect the display cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Samsung Galaxy Tab S7 Plus Antenna Board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or you fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position; you will need to bend it in the same way when connecting a new screen.
  18. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the screen: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the screen: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the screen: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screen from the frame.
  19. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Unfasten the frame bracket: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Unfasten the frame bracket: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Unfasten the frame bracket: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom left = 9 screws
    • Bottom right = 14 screws
    • Top right = 12 screws
    • Top left = 15 screws
  20. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the frame bracket: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the frame bracket: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the frame bracket: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
  21. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Disconnect the battery: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Disconnect the battery: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
  22. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Disconnect the antenna board's interconnect cable: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Disconnect the antenna board's interconnect cable: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the antenna board interconnect cable's press connector secured to the antenna board.
  23. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Unfasten the antenna board: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Unfasten the antenna board: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips 00 screwdriver to remove the 2 mm screw securing the antenna board to the frame.
  24. Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the antenna board: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the antenna board: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S7 Plus Antenna Board Replacement, Remove the antenna board: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger into a gap between the antenna board and the frame.
    • Pry up with the spudger to separate the antenna board from the frame.
    • Remove the antenna board.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
168,220 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 438
