Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement
  1. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the iOpeners in a microwave for 1-2 minutes.
    • The iOpeners will be hot. Use caution and hold the tabs on the ends.
    • Place heated iOpeners on screen edges to heat the adhesive.
    • For more detailed instructions on how to use the iOpeners, please refer to the iOpener Instructions.
  2. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the screen assembly from the back by wedging the picks between the two components.
    • Slide the picks along the edge and leave them holding the device open all around the edges.
  3. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
    • Insert the picks to hold the two components apart once a gap is created.
  4. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all edges have been disconnected, carefully lift the screen off by pulling one side up.
    • Be careful not to cut yourself. Any broken glass from the screen will be sharp.
  5. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, gently peel up on the silver tape covering the connector.
  6. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to get under the connector piece. This will allow you to remove the front panel assembly from the rest of the device.
  7. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the connecter from the inside of the device.
    • Lift the screen to separate the front panel assembly from the rest of the device.
crwdns2935229:012crwdne2935229:0
Kaley Sapper
crwdns2935283:004/18/18crwdne2935283:0
805 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G5, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S16-G5, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S16G5
Question. How is the new LCD re-attached? Do you reheat the old adhesive so that it sticks to the new LCD? Or do you need to apply new adhesive? Or is there a double-sided tape to re-attach the new LCD?
Dick Campbell - crwdns2934203:0crwdne2934203:0
Hi,
my glass broke, not the LCD itself. Do you know how to separate LCD and glass, change the glass, and put it back again?
I have found a video on the internet but a laminating machine seems needed?? Any easier solution?
Thanks
Stefano Vaccarone - crwdns2934203:0crwdne2934203:0
I would like to know also
Chris -
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 11,602
