Follow this guide if you need to replace your Samsung Galaxy Tab S2 8.0 screen. If your screen is cracked or not displaying images as it should, replacing it will fix these problems.
crwdns2936621:0crwdne2936621:0
Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
Put an opening pick in the gap created, in between the screen and the panel.
Repeat all around device, putting 2 picks on top and bottom, and one on each side.
Carefully remove the small suction cup from the corner without moving the screen.
Place the small suction cup in the center of the screen and lift to remove screen.
Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
Carefully lift the plastic opening tool to detach the ribbon from the tablet.
The screen is now detached from the rest of the tablet.
crwdns2935229:08crwdne2935229:0
