If the tablet is taking blurry pictures or unclear pictures, replacing the camera should solve the problem.
Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
Put an opening pick in the gap created, in between the screen and the panel.
Repeat all around device, putting 2 picks on top and bottom, and one on each side.
Carefully remove the small suction cup from the corner without moving the screen.
Place the small suction cup in the center of the screen and lift to remove screen.
Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
Carefully lift the plastic opening tool to detach the ribbon from the tablet.
The screen is now detached from the rest of the tablet.
Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
Use the plastic opening tool to lift and remove the plastic motherboard cover.
Use the plastic opening tool to detach the camera's ribbon from the motherboard.
Carefully remove the camera from the motherboard.
