Samsung Galaxy Tab S 8.4 Micro USB Port Replacement
  1. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4 mm Phillips #000 screws securing the micro USB port.
  5. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, disconnect the charge port from the motherboard.
    • Once disconnected, lift to remove the charging port.
crwdns2935229:032crwdne2935229:0
Trent Chapman
crwdns2935283:010/01/15crwdne2935283:0
1,384 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-15, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 12-15, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S12G15
It is so amazing and it works!
alva chan - crwdns2934203:0crwdne2934203:0
Thanks a lot!
You make me a big economy by doing this myself with YOUR instructions !
Raphael
refelo123 - crwdns2934203:0crwdne2934203:0
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
tailoredtoteach - crwdns2934203:0crwdne2934203:0
Thanks for the instructions, it looks simple , so I ordered the docking assembly and I replace it by myself.
You saved me a lot of money, thanks again!
wim-zelf - crwdns2934203:0crwdne2934203:0
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
Philip Holly - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 15,657
