Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull up on tab that connects the charging port to the motherboard
crwdns2935229:05crwdne2935229:0
Jonathan Romine
crwdns2935283:009/12/16crwdne2935283:0
1.072 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-2, Lacy Fall 2016 crwdns2935289:0USF Tampa, Team 9-2, Lacy Fall 2016crwdne2935289:0
USFT-LACY-F16S9G2
Thank you for your help. You are awesome :-)
Kim Williams - crwdns2934203:0crwdne2934203:0
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - crwdns2934203:0crwdne2934203:0
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 4,154
