This replacement guide will show you how to replace the speaker in your Samsung Galaxy Tab E Lite 7 Kids. You will need to follow the instructions carefully as to not damage any fragile components in your tablet.
            Using a plastic opening tool, wedge in the seam between the screen and the case.
            Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
            After separating the latches holding the screen and case together, slowly take the screen off the case.
            Using a spudger, pry up the speaker ribbon cable.
            Using the plastic opening tool, place it on the opening in the plastic around the speaker.
            Pry the speaker out of its seat.
