This guide will walk you through replacing the speaker on the Samsung Galaxy Tab E.
            Insert the plastic opening tool by wedging it between the device's screen and back cover.
            Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
            This process will become easier as more clips are separated.
            Use your hands to gently pull the back cover off the device after about half of the clips are separated.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Locate the speaker in the top right corner of the back casing. Use a pair of tweezers to pull peel up the film connecting the speaker to the case.
            Once you've detached the film connecting the speaker to the case, use the tweezers to remove the speaker completely.
Then what? How does this fix the problem? Can I tweek the speaker? Do I buy a new, more powerful speaker? What is your point in this post?
@Janet Sorry I know you probably wont even see this, but its to help those who wish to replace a broken speaker, its not about implanting a 9” subwoofer. Sorry but sometimes the simplest of explanations will often answer your questions.
sannas30 -
