Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement
  1. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement, Back Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement, Front Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement, Front Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard.
    • To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
  5. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you've undone the connector lock, use a pair of tweezers to pull the cable front its housing.
  6. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
    • You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
    • Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
Dave Dorzback
crwdns2935283:009/28/16crwdne2935283:0
650 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 1-4, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S1G4
To install the new screen, install the connector at the top first and dry fit before installing and make sure you align the Button and Camera.
Oscar C - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,518
