crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2936621:0crwdne2936621:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
Lift the back panel off of the device.
Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
Slide the orange battery ribbon cable out of the ZIF connector.
Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
Lift the retaining tab and withdraw the black LCD ribbon.
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
crwdns2935229:046crwdne2935229:0
crwdns2944067:09crwdne2944067:0
Used this guide up until the disconnecting of the battery in order to fix the black screen of death. Very very helpful. Thank you.
If you have my kind of bad luck — where the latch for the battery flex cable connector sticks to the tape when you remove the tape, and then it will not snap back into place — don’t worry about it too much, because the connector tension will hold the flex cable in place. Just put the tape back over the top as directed.
Why does it say you need a heat gun?
To loosen the adhesive. A hair dryer works well too
how to calibrate the new battery?
when device switched off due to 0% of battery - there is impossible to boot it even with charging. there is required to open a tablet and charge the battery from another source.
