Using the plastic opening tool to open up the device, wedge in the seam between the screen and the back cover.
Slide the tool around all the edges and remove the screen from the back cover.
Unplug the battery connection carefully using the plastic opening tool.
Before changing the motherboard, disconnect the press connectors using the plastic opening tool.
Unscrew the ten 4mm PH000 bolts holding the motherboard to the device.
Remove the mother board from the device by carefully lifting it out.
Remove the last screw holding down the speaker.
Remove the speaker using the blue opening tool.
