If your tablet has a broken touch screen glass (digitizer), LCD display or you want to chang the micro USB charging port, loudspeakers, audio jack connector, etc., with this guide we will help you to do it.
crwdns2936621:0crwdne2936621:0
Put the scotch tape in order not to scatter pieces of glass.
Remove any memory card and SIM card (if the tablet is 3G version).
Using plastic tools remove the back / battery cover.
Remove the two screws and disconnect the charging port flex cable from the main board.
Use a plastic tool to unstick the flex cable from the middle frame.
The battery is stuck to the middle panel.
Use the white sticker to remove it.
2x loudspeackers
Power & Volume buttons flex cable
Audio jack flex cable
Front camera
Wi-Fi antenna
Use a heat gun or hair dryer and warm the touch screen glass. This will make the adhesive more flexible and the separation easier.
Beware for the menu buttons flex cable.
Always test the new spare part before final installation.
Transfer the black tape from the old display. It keeps the distance the display from the battery and protects it from overheat.
If the adhesive tape is not in good condition you must install a new one.
Start with reassembling.
Did you do it successfully.
crwdns2935229:018crwdne2935229:0
crwdns2917034:0crwdne2917034:0
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
