Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
After the battery is disconnected, use the pulling tab to safely remove the battery.
Disconnect Audio Jack from Motherboard.
Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
