Samsung Galaxy Tab 3 10.1 Motherboard Replacement
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use nylon-tipped tweezers to remove the motherboard.
crwdns2935229:014crwdne2935229:0
Corey Brown
crwdns2935283:006/24/16crwdne2935283:0
9,184 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Great guide, project completed.
Edgar Merced - crwdns2934203:0crwdne2934203:0
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
DARIO GASTAUDO - crwdns2934203:0crwdne2934203:0
very easy to destroy the Galaxy. finicky to the max!
ein Stein - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 10,417
