Samsung Galaxy Tab 2 7.0 Battery Replacement
  1. Samsung Galaxy Tab 2 7.0 Battery Replacement, Preparing Your Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 2 7.0 Battery Replacement, Preparing Your Device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 2 7.0 Battery Replacement, Preparing Your Device: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power the device down completely
    • Remove the SD card from the SD card slot.
    • Remoce the sim card from the sim card slot if you have the sim card versions show in one of ghr images
  2. Samsung Galaxy Tab 2 7.0 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 2 7.0 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the prying tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Be sure to unclip all of the clips on the back panel or it will be difficult for you to pull it off and may damage the tablet.
  3. Samsung Galaxy Tab 2 7.0 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 2 7.0 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery Flex Cable from its socket by placing the pry tool under the wires and gently prying it out.
    • When you are placing in the new battery, it helps to connect the socket first or else it becomes difficult to properly align once the battery is in place.
  4. Samsung Galaxy Tab 2 7.0 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 2 7.0 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 2 7.0 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips precision screw driver remove the six 4 mm screws holding the battery in place.
    • Once the battery is loose, remove as shown.
crwdns2935229:050crwdne2935229:0
Paul
crwdns2935283:003/05/15crwdne2935283:0
2 183 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 11-5, Blackburne Winter 2015 crwdns2935289:0Sam Houston State, Team 11-5, Blackburne Winter 2015crwdne2935289:0
SHSU-BLACKBURNE-W15S11G5
crwdns2947412:015crwdne2947412:0
thanks so much for this guide! Its easy to follow and may have just answered a question I've been asking myself for months.....
karmacroft - crwdns2934203:0crwdne2934203:0
I have using my phone last 5 year its the Samsung galaxy tab 2. I have rooted my device and also have installed cm12 custom ROM in it. I also have install cwm recovery . but before 3 week I just tried to on my but it doesn't I looked out some videos from YouTube which says to connect your phone with your laptop I done that it start charging I felt very good I kept it for a day .next try to on that it stared but after some 'Samsung galaxy tab 2 GT p3100 ' it started my recovery I am help less now now I always try to do that it does the same thing ....... Plz help .............
vermaujjwal2 - crwdns2934203:0crwdne2934203:0
wrong answer to that tablet section
Ron Andres -
My Galaxy Tab kept rebooting. We removed the battery and then reassembled everything and now it won't start at all. Ideas?
Jan Morrow - crwdns2934203:0crwdne2934203:0
@tvljan You removed the battery, put it back together and it doesn't start? You did REPLACE the battery, right? Otherwise it's not surprising it doesn't start. The other possible issue could be that when you replaced the battery (assuming you did) that the connection clip/plug didn't make a proper connection or that something in the socket broke when you removed the old battery. It's been some months, so maybe you have figured it out, but I post that in case others have a similar problem... it's most likely a simple cause, whether or not the solution is simple.
Lowell Montgomery -
Nice guide. :-) Before reading it, I wasn't sure the battery was replaceable (I think I remember the user guide saying it wasn't). But the tablet my wife has been using for the last few years still works fine, just the battery wasn't holding a charge at all. Hopefully the one I put in will make her feel like it's "new again".
For the benefit of others, I'll say that popping all the clips around the edge is a task which is easier said than done. I had difficulty getting some of the edge clips to release, so just opening the device took a while. It definitely helps to have a decent set of tools for the job. A thin, flexible guitar pick was the most helpful for getting the last clips free (to open the device).
The battery screws were the biggest re-assembly pain-point. Getting the battery "loops" aligned with the screw holes is tricky, to say the least. I found I had to use pry tools to push the battery one direction and another to acheive alignment and firmly push it down to allow driving the screws.
Lowell Montgomery - crwdns2934203:0crwdne2934203:0
Where do you get a new battery?
kholden03 - crwdns2934203:0crwdne2934203:0
I have one problem with this initial inquiery, my tablet won't turn off. Mine can be restarted by pushing and holding it down . Once it goes through the boot up and onto the lock screen it is stuck there. It will not do, nor can I get it to do anything else but reboot again by holding the power button down. What is a solution?
Holly Hilburger - crwdns2934203:0crwdne2934203:0
Just disassemble very carefully to ensure no foreign objects make contact with the internal components.
When you disconnect the battery cable connector the tab will turn off.
Removing the battery should quit the bootloop.
Billy Beag -
How do you take the clips off? Where are they?
Kris McMahon - crwdns2934203:0crwdne2934203:0
Pry apart the case carefully and they snap open.
Paul Wicks -
I want a new battery, where can I get it?
الباز - crwdns2934203:0crwdne2934203:0
I ordered one from Amazon and got it in one day!
Paul Wicks -
Cómo ago para que cargue directo ya que no hay cargadores de este modelo, pero mi tablet aún funciona tiene 10 años
Reclutador Prime - crwdns2934203:0crwdne2934203:0
Thanks for the instructions! The hardest part was opening the tablet.
Paul Wicks - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 45,706
