Samsung Galaxy SIII Mini Display Assembly Replacement
crwdns2936621:0crwdne2936621:0
  1. Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
  3. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  6. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  7. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently separate the menu buttons flex cable from the touchscreen.
  8. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the display is left on the frame, use the same techniques to remove it.
  9. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  10. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  11. Samsung Galaxy SIII Mini Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • That's all.
    • Did you do it successfully?
crwdns2935229:018crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
195,084 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01,429crwdne2935297:0
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - crwdns2934203:0crwdne2934203:0
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 17,745
