Samsung Galaxy S8 Plus Motherboard Replacement
    • Step by step tutorial about dismantling the logic board from Galaxy S8+. If you need more information ask them in the comments!
Alex Sander
crwdns2935283:002/28/17crwdne2935283:0
38 951 crwdns2915208:0crwdne2915208:0
crwdns2935297:0201crwdne2935297:0
How do you then fix the imei to match the back of the phone and to work with the plan it was on when broken; having to register/activate a new device for a motherboard repair is bull$][!+, and doesn't take care of the problem for the customer.
chrisjwellnitz - crwdns2934203:0crwdne2934203:0
Hello, The connector from the battery to the motherboard has been damaged. Due to water getting in there’s been corrosion on the connectors which has eaten away on 2 of the capacitors there down to the silicon. Is there anyway to fix this? Perhaps any way to add material back or make some kind of jumper? I doubt I can get a replacement motherboard, but if you know if this can be done that would be great.
Ggarcia - crwdns2934203:0crwdne2934203:0
..does this correct a problem with the SIM card holder or is that a separate board in the phone?
Sigmund -
Sigmund - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,723
