Prereq only
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
Lift on the suction cup, and insert an opening pick under the rear glass.
Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
Slide the opening pick down the side of the phone, separating the adhesive.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use the opening picks to slice through any remaining adhesive and open the phone slightly.
Remove the glass from the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
