Samsung Galaxy S8 Active Rear-Facing Camera Replacement
  1. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, SIM Tray/Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, SIM Tray/Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
    You dont need to remove the SIM tray.
    Gregg Stanley - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, NFC Antenna and Charging Coil Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, NFC Antenna and Charging Coil Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, NFC Antenna and Charging Coil Assembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
    not needed as near as I can tell
    jason davis - crwdns2934203:0crwdne2934203:0
    You dont need to remove these.
  3. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
  5. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  6. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  7. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
    You only need to remove the top seven, the rest aren't necessary to remove the battery.
  8. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
  9. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Loudspeaker Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Loudspeaker Assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Loudspeaker Assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the loudspeaker assembly using the flat end of a spudger.
    Step nine (removing the loudspeaker assembly) did not seem necessary to replace the battery pack. Skipping this would save some time and risk. Otherwise GREAT instructions! And completed sucessfully! Sam Caldwell rev.sam.caldwell@gmail.com
    Sam Caldwell - crwdns2934203:0crwdne2934203:0
    broke 2 spudgers on this make be careful
  10. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Front-Facing Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Front-Facing Camera: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Front-Facing Camera: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the front-facing camera flex cable from the motherboard using the flat end of a spudger.
    • Use tweezers to gently lift the camera from its slot.
  11. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Iris Scanner: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Iris Scanner: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Iris Scanner: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the iris scanner flex cable from the motherboard using the flat end of a spudger.
    • Use tweezers to gently lift the iris scanner from its slot.
  12. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Motherboard: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery flex cable using the flat end of a spudger.
  13. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 3.5 mm screw using a Phillips #00 Screwdriver.
  14. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Volume Up, Volume Down, and Bixby button flex cable using the flat end of a spudger.
  15. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the display flex cable using the flat end of a spudger.
  16. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the charging port flex cable using the flat end of a spudger.
  17. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the black and white antenna cables using the flat end of a spudger.
  18. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motherboard rests on top of the daughterboard, and there is a flex cable connecting them. Disconnect the flex cable that connects the motherboard to the daughterboard using the flat end of a spudger.
  19. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the flat end of a spudger at the top edge of the motherboard.
    • Carefully pry up and remove the motherboard.
  20. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Rear-Facing Camera: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Rear-Facing Camera: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the motherboard over so that the rear-facing camera is face down.
    • Disconnect the camera's flex cable using the spudger.
  21. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the motherboard back over.
    • Pop the camera out of its socket using your fingers or the flat end of a spudger.
    • When removing the camera with your fingers, make sure you do not put too much bending pressure on the rest of the motherboard or else it may break.
    • If you choose to just use your fingers (which was actually the easier way to do it), make sure your avoid touching the lens of the new camera. Otherwise, you will have blurry pictures with your new camera!
Erik Mauk
crwdns2935283:001/24/19crwdne2935283:0
1.450 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G1, White Winter 2019 crwdns2935289:0Cal Poly, Team S2-G1, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S2G1
crwdns2935297:011crwdne2935297:0
I need a rear facing camera for my samsung galaxy s8 active. Sm-g892a. Do you sell the camera or do you know where I can buy a new one?
Justin Rauch - crwdns2934203:0crwdne2934203:0
So I took this apart and either the camera is shot itself (unsure how to determine) or is it possible a ripped finger print scanner ribbon could somehow disable the camera from working? I can't imagine so but I was curious and wanted to ask since your site has helped me TONS on repairs at home. Thanks!
Tyler Giacchino - crwdns2934203:0crwdne2934203:0
I dont have a fingerprint sensor and my cam works perfectly fine. G892A
i broke it by opening backdoor and breaking ribbon
David Dibean Jr - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,124
