Use this guide to remove or replace the headphone jack in your Samsung Galaxy S8 Active.
This guide involves removing the back cover of the device, so you will need replacement adhesive to reattach the back cover to the phone.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion is decreased.
Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
Press gently to eject the SIM tray.
Remove the SIM card tray from the device.
Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
Take off the rubber bumpers from the top and bottom edges of the device.
Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
Insert the Jimmy tool under the edge of the back cover.
Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
Slide the Jimmy tool down the sides of the device, separating the adhesive.
Use the opening pick to slice through any remaining adhesive.
Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
Slowly flip the cover over and set it down on top of the rest of the device.
Disconnect the fingerprint flex cable using the flat end of a spudger.
Remove the back cover.
Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
Remove two 2mm screws using a Phillips #00 Screwdriver.
Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
Remove the loudspeaker assembly using the flat end of a spudger.
Remove one 3.5 mm screw using a Phillips #00 screwdriver.
Disconnect the headphone jack flex cable using the flat end of a spudger.
Insert the Phillips #00 Screwdriver into the headphone jack located on the bottom edge of the device.
Gently push the screwdriver upwards, ejecting the headphone jack.
