Samsung Galaxy S7 Rear Camera Lens Replacement
    • Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
    • If you are replacing the entire bezel, skip this step and follow the instructions in the next step.
    My lenses did not come with with adhesive on either side
    Joshua albano - crwdns2934203:0crwdne2934203:0
    Thank you, you just saved me $80. I took it to a place that gave me a quote of $80. I bought the kit from Amazon.com for $10, we already have a hair dryer at home. Because I was trying to be very careful, the whole process took me 15 minutes. Very helpful. So thank you.
    Don Johnson - crwdns2934203:0crwdne2934203:0
    I took the broken glass off, removed adhesive and placed tape over the camera to make sure there was no additional glass inside. As stated in video the can cause additional problems with focus. Good thing I did because additional glass came out through out the day.
    Joshua Silbernagel - crwdns2934203:0crwdne2934203:0
    • Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
    • If you follow this procedure, you will need new adhesive to reinstall the rear case. Follow this guide to reinstall the camera bezel adhesive as well as the rear cover adhesive.
    I did ut. It worked perfectly untill i realized my camera could not focus anymore... i ordered a new spare part and will try to remove the replacmenet one to clean it. I hope it doesn't come from the lens...
    Baptiste Le Sueur - crwdns2934203:0crwdne2934203:0
crwdns2935229:034crwdne2935229:0
Evan Noronha
crwdns2935283:002/05/15crwdne2935283:0
226.856 crwdns2915208:0crwdne2915208:0
crwdns2935297:0168crwdne2935297:0
crwdns2947412:012crwdne2947412:0
THANK YOU SO MUCH for the first video!!!
Grace Arnott - crwdns2934203:0crwdne2934203:0
Follow up... What happens if there is a bit of dust? Is there a way to get rid of it?
I ordered 2 lens replacements and neither one of the lenses have adhesive on either side do I need to buy some kind of adhesive sepratly or should 1 or these sides already have it on there
same thing with mine josh albano i just plopped it in and am going to hope for the best.
John Biello - crwdns2934203:0crwdne2934203:0
How can I make sure I don't get my replacement glass in backward.....because my focus is still gone. I'm devastated because I purchased this phone specifically for the camera to take pictures to upload to my eBay account. I worked for almost a full year before I could afford to buy this camera phone and I purchased it outright from straight talk. I own my camera and it is not insured. I followed your directions to replace my lens and now I'm worried I might have it in backward. How can I tell if the lens is in place incorrectly? By the way, my phone has never been dropped. It has been protected by an otter box since its purchase. My lens seemingly self-imploded. Just the strangest thing. Other than the lens, my camera doesn't have a scratch on it! Thank you for any help. Molly
Molly Azbell-Thompson - crwdns2934203:0crwdne2934203:0
Mine shattered too with no impact occurring, I just picked it up today at work and the glass cut my finger. I see that there are some claims out there like ours, Molly.
victoriad1219 - crwdns2934203:0crwdne2934203:0
This was so easy and saved me more $50-$90! Except there's a lot of glass dust under the new lense. I tried to get as much out as I could. Is it worth trying to get the new glass off and knock more out? I did buy two pieces in case I messed up.
Dara Abrams - crwdns2934203:0crwdne2934203:0
That might be a good idea, I'd worry about the glass dust possibly spreading? I'd recommend canned air to blow out the pieces (watch your eyes!). You might also be able to use some sticky putty to reach in there, of course you risk getting the putty stuck in the camera assembly, so try the canned air first!
Sam Goldheart -
where or how do i buy the lens? can’t find it in the parts
Renegade Zed - crwdns2934203:0crwdne2934203:0
What do I order to replace the lenses glass only.
Confused as to what to order.
Perry Hirsbrunner
William Hirsbrunner - crwdns2934203:0crwdne2934203:0
Do I have to remove benzel on back of camera to get the glass out?
Thanks
William Hirsbrunner
My right glass is broken, camera still works perfectly, I'm perplexed 🤔 I'm glad but..
foodexpedite - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 153,669
