Follow this guide to replace the home button on a Samsung Galaxy S6.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Place the iOpener in the center of the microwave.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Repeat the heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick under each edge to prevent the adhesive from resealing.
Use an opening pick to slice through any remaining adhesive.
Remove the rear glass.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
Firmly grasp the edge of the midframe assembly.
Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
Lift the midframe assembly up to separate it from the rest of the phone.
Use the flat end of the spudger to disconnect the battery connector from its socket on the motherboard.
Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
Use the flat end of the spudger to disconnect the home button connector.
Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
Disconnect the earpiece speaker assembly cable connector from the motherboard.
Lift the camera-side end of the motherboard to separate it from the display frame.
Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
If your display glass is badly cracked, tape over the glass to contain stray glass and make prying easier.
Reheat the iOpener.
Lay the iOpener across the S6 display. After two minutes, shift the iOpener to the other half of the screen.
Insert the opening pick in the battery-side edge of the phone, between the frame and display, at an upward angle.
Slide the pick down the edge of the display to separate the adhesive underneath.
Stop cutting when you get to the daughterboard to avoid the delicate capacitive button under the display.
After cutting the adhesive, leave the pick in the side of the display to prevent the display from re-adhering to the frame.
Slide the pick along the bottom edge of the phone, from the headphone jack to just past the charging port.
Do not insert the opening pick more than 0.25 inches (~6mm) to avoid damaging the home button.
Insert an opening pick about 0.5 inches (~12mm) under the bottom corner of the display, near the headphone jack.
Leave the pick under the display to prevent the button from re-adhering to the display.
Insert an opening pick about 0.5 inches (~12mm) under the opposite bottom corner of the display.
Slide an opening pick along the side of the phone opposite the battery to separate the adhesive underneath.
Slide a pick along the top of the phone towards the vibrator.
Use an opening pick to gently pry the battery side of the frame away from the display.
If the display and frame to not separate easily, use an opening pick to cut any remaining adhesive. If cutting is difficult, reheat and reapply an iOpener.
Route the display's flex cable through its hole in the frame in order to fully separate the right edge of the display.
After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
Remove the single 3.0mm Phillips #00 screw securing the daughterboard to the display frame.
Insert the pointed edge of the spudger into the groove next to the right soft button LED cable.
Gently lift the LED cable off the display frame.
Insert the pointed edge of the spudger into the groove above the left soft button LED cable.
Lift the left soft button LED cable off the plastic frame.
Use the pointed edge of the spudger to separate the home button ribbon cable from the display frame.
Use the pointed end of a spudger to push the home button cable through the display frame.
Flip the display frame over and use the pointed end of a spudger to pull the home button cable completely through the hole.
Slide the spudger under the cable to continue separating it from the frame.
Once the cable is entirely separated from the frame, use a spudger to push the home button to the far left of its bracket.
Use a spudger to push the home button up and out of its bracket.
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
crwdns2935229:023crwdne2935229:0
So it's literally the last thing you remove on the entire stinking thing /facepalm
Jakim Toomey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Can i change the fingerprint sensor? My fingerprint sensor is having a issue: "make sure the home key is clean and dry". But its so clean and so dry. Can sameone help me? Would I fix that sensor or change it to another?
Caio c - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You forgot to mention how to enable the fingerprint sensor when you replace the home button. When you replace the home button the fingerprint sensor wont work. Not sure what Samsung does but it has to be a software flash to allow the new part to marry to the mother board. There are lots of how to articles and videos that are half assed and just give enough info to get you into trouble. Though I wouldnt pay Samsung $100 to replace a button, these facts should be included in the repair article. Im really surprised no one has the fix for this in the form of an APK. Ive seen lots of screen replacement videos and all are half assed that show you the wrong way to remove the screen digitizer. I ripped my home button and back buttons circuit because of idiots that post how to videos that skip these important steps. I wish I would have paid the extra $$ and had the local shop do my repair from the start. He told me that the sensor wont work after repair and so far he is correct.
GGG - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I broke my display doing this :( I suggest you not to do it if you are not 100 % sure of yours skills.
Andrea Silvestro - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is such BS. there is a faster way to get to the button if you think f it. they are just trying to make it seem difficult/complex so you pay others to do it.
Jay Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
