Follow this guide to learn how to replace the screen and the front plastic frame on your Samsung Galaxy S6 Edge. This guide will show you how to remove all the components from the frame, which includes the digitizer, OLED display, display frame, and home button.
Use this guide if you are replacing the display assembly and front plastic frame together. If your replacement part does not come with a plastic frame, follow this guide instead.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
If your replacement part looks like the first image, follow the display assembly and frame replacement guide.
If your replacement part looks like the second image, follow the display assembly replacement guide.
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Place the iOpener in the center of the microwave.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Repeat the heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick under each edge to prevent the adhesive from resealing.
Use an opening pick to slice through any remaining adhesive.
Remove the rear glass.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
Disconnect the home button ribbon cable from the motherboard.
Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
Disconnect the earpiece ribbon cable from the motherboard.
Grip the motherboard on both edges toward the top of the device.
Lift the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
Disconnect the daughterboard ribbon cable from the underside of the motherboard.
Insert an opening pick underneath the battery and slide it across to break up the adhesive underneath.
Twist the opening pick to fully dislodge the battery and remove it.
Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Lay the replacement battery in place, but do not apply adhesive yet. Resume re-assembly until the motherboard is in place (STEP 18).
Apply new pre-cut adhesive or double-sided tape onto the phone frame, around the perimeter of the battery compartment, but not in the rectangular cutout in the center (which is actually the back side of the display).
Temporarily connect the battery connector to the motherboard to ensure proper battery alignment.
Press the battery firmly into place for 5-10 seconds. Disconnect the battery and resume re-assembly.
Remove the two 2.5mm Phillips #00 screws.
Using the pointed end of spudger, pry up the small section of daughterboard secured with a light adhesive.
Lift the daughterboard up and away from the body of the phone to remove it.
Press the tip of a spudger in the gap in the display frame under the vibrator, to pry it off the adhesive.
Remove the vibrator from the display assembly.
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the rear glass.
crwdns2935229:066crwdne2935229:0
Would it be possible to point out which connectors are for the LCD/touch screen, as my screen is not broken but part of the my touch screen will not work and I would like to check the connector is applied properly. Also would it be possible to purchase that suction cup somewhere?
It does not seem as though steps #25, #26, and #27 are necessary for this specific project: Display Assembly Replacement. Otherwise an excellent guide!
You are right! The guide has been re-organized to leave those steps out now.
Does anybody know if there is actually any difference between the CDMA and GSM screens? I got a galaxy s6 edge with a broken screen, and the back said verizon, but when I opened it up, the charging port flex cable said, SM-G925A, which is the AT&T version right? I have a working screen I took off of a working verizon phone, but it doesn’t work on the ATT phone. I’m not sure if its that the motherboard is damaged, or if the Verizon screen won’t work on the AT&T phone.
I have samsung s7 edge
