crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Place the iOpener in the center of the microwave.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Repeat the heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick under each edge to prevent the adhesive from resealing.
Use an opening pick to slice through any remaining adhesive.
Remove the rear glass.
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
Firmly grasp the edge of the midframe assembly.
Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
Lift the midframe assembly up to separate it from the rest of the phone.
Use the flat end of the spudger to disconnect the battery connector from its socket on the motherboard.
Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
Use the flat end of the spudger to disconnect the home button connector.
Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
Disconnect the earpiece speaker assembly cable connector from the motherboard.
Lift the camera-side end of the motherboard to separate it from the display frame.
Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
Use the pointed edge of the spudger to lift the earpiece speaker assembly from the display frame.
Use tweezers to lift the assembly out once it's been pried loose.
crwdns2935229:09crwdne2935229:0
