The removal of the SIM card is a very simple process and tools are required to complete the objective. You can also use this guide to remove the MicroSD card. The MicroSD card would follow the same procedure as the SIM card since it goes in the slot that is just on top.
            Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
            Gently pry and twist the flexible rear cover off the back of the phone.
            Use your fingers to remove the SIM card
crwdns2935229:08crwdne2935229:0
You need to remove the battery to remove the Sim card, but you do not need to remove the battery for the micro Sd card
