Samsung Galaxy S4 Mini Charging Assembly
  1. Samsung Galaxy S4 Mini Charging Assembly, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Charging Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Charging Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Charging Assembly, SIM Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S4 Mini Charging Assembly, SIM Card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Charging Assembly, SD Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Charging Assembly, Charging Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 10 4.0 mm Phillips screws on the back of the phone using the #00 Phillips screwdriver.
    • Not needed, but Tweezers can be helpful in removing the screws from their holes, as their size makes removal a tad difficult.
  7. Samsung Galaxy S4 Mini Charging Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting at the USB port, slide a plastic tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge you will feel the clips release.
  8. Samsung Galaxy S4 Mini Charging Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  9. Samsung Galaxy S4 Mini Charging Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 flex cables shown that attach to the USB board, Tweezers can be especially helpful here.
  10. Samsung Galaxy S4 Mini Charging Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry underneath the charging port using the plastic opening tool to separate it from the double sided tape below.
  11. Samsung Galaxy S4 Mini Charging Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once its released, gently lift the main board and remove the USB board containing the charging port.
crwdns2935229:035crwdne2935229:0
Francis Barnett
crwdns2935283:009/23/14crwdne2935283:0
1.104 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-2, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 9-2, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S9G2
crwdns2935297:011crwdne2935297:0
if i open the device like this, can i solder cables on the usb port to connect a wireless charging reciever?
Getriebesand - crwdns2934203:0crwdne2934203:0
I was looking for the same solution, and I think it is possible, a closer look at the USB port from various spare parts suppliers, I was in doubt if mine would look the same as the one displayed here, after disassembling my phone, it turned out to be this one: http://bit.ly/1GR4SzP
And it is possible, when messuring connection points, it turns out CN2 on the bord is the +, and - you can fit onto the side of the USB connector itself.
Kenneth H. Nielsen -
I have created a Guide describing the addition of wireless charging, it is in no way affecting the phones stability.
Works great with the S4 mini I9195 LTE version, but mind the different spare part (as linked above: http://bit.ly/1GR4SzP).
megaoetzwuchst - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 26,136
