Use this guide to replace the front-facing camera in your Samsung Galaxy S4.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
Slide the opening tool along the seam, separating the plastic clips as you go.
Continue prying around the corner of the phone.
Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
Again, pry around the corner, to the power button side.
Slide the opening tool along the seam.
Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
Remove the midframe from the display assembly.
Remove the upper display assembly bracket.
Using the flat end of a spudger, disconnect the front-facing camera cable connector.
crwdns2935229:066crwdne2935229:0
crwdns2947412:010crwdne2947412:0
Hi my front camera is bright white all of a sudden... is it broken or am I I'm some sort of mode it's only the front facing cam. .
James - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Any instructions for replacing the front speaker? I think I clogged it with glue when replacing the front glass.
Thanks!
Bill Carden - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great set of instructions! Pictures are very accurate and helpful! When it only take 5-10 mins to do something you have never tried before, you know the instructions were excellent! Thanks
laura - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Excellent instructions. At step 12, the bracket is fragile and can easily ping off across the room so be careful. Thanks.
Ageingjedi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My front camera is a bright white also, even on video recording but you can still hear sound.
Cin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
