Use this guide to remove or replace the battery.
If your battery is swollen, take appropriate precautions.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
crwdns2935229:0100crwdne2935229:0
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
