Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement
  1. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
    • Do the lower end first, and then the upper.
    • Pull the antenna cable out.
Taylor Catlin
crwdns2935283:001/15/13crwdne2935283:0
82 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-37, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 18-37, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S18G37
crwdns2942667:0crwdne2942667:0 4,354
