The battery removal is the next step in majority of the replacement guides.
If your battery is swollen, take appropriate precautions.
Turn the phone over so the back is facing you.
Hold phone to see notch on the side of the back plate.
Apply pressure to the back plate to remove the back plate.
Using your index finger, pull the top of the battery. Then pull the battery towards you.
The battery will fall out easily.
