Samsung Galaxy Prime Front Facing Camera Replacement
  1. Samsung Galaxy Prime Front Facing Camera  Replacement, Removing back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Lift on the tab to pry the back cover off of the phone.
    • Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
  2. Samsung Galaxy Prime Front Facing Camera  Replacement, Remove The Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Samsung Galaxy Prime Front Facing Camera  Replacement, Remove The SD And LCD Ribbon Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Prime Front Facing Camera  Replacement, Remove The SD And LCD Ribbon Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the SD card and Sim card, look above the battery bay and slide the card out.
    • Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
  4. Samsung Galaxy Prime Front Facing Camera  Replacement, Removing screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back.
    • Keep the screws on a magnetic mat or in a secure location.
  5. Samsung Galaxy Prime Front Facing Camera  Replacement, Seperating Bezel and Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Prime Front Facing Camera  Replacement, Seperating Bezel and Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
    • Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
    • You can also push the screen out in the empty slot where the battery was to separate.
    • It is important to be quick but careful when separating the screen and plastic bezel because the glue could cool down and re-bond the two parts.
  6. Samsung Galaxy Prime Front Facing Camera  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Prime Front Facing Camera  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit.
    • Lift from the top of the loudspeaker unit to release from the phone.
    • You do not need to remove the motherboard to do this.
  7. Samsung Galaxy Prime Front Facing Camera  Replacement, Front Facing Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic spudger to disconnect the ribbon cable from the motherboard.
    • The camera will be free to remove.
Alex Boyle
crwdns2935283:007/31/18crwdne2935283:0
374 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G1, Liner Summer 2018 crwdns2935289:0UW Tacoma, Team S1-G1, Liner Summer 2018crwdne2935289:0
UWT-LINER-SU18S1G1
crwdns2942667:0crwdne2942667:0 1,351
