This guide will show you how to replace the home button for the Samsung Galaxy Prevail 2. No background information is required.
Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
Gently pull the battery out of the phone.
Unscrew all of the screws.
Insert the plastic opening tool between the silver frame and the white face of the phone to pry off the front face.
Use your thumbs to separate the motherboard from the back of the phone
With the plastic opening tool, lift up the flap to to fully open the motherboard.
With the plastic opening tool, lift the second flap up.
Choose the motherboard side that contains the home button, as shown in the image.
Use the plastic opening tool to push the home button out.
