The Samsung Galaxy On5 speaker is located in the back of the phone. Now getting to isn't difficult to get to, but once you're in the phone chaise everything is smooth sailing.
Locate the side notch that allows you to open the back casing.
Use a plastic prying tool or your fingernail to pop the back cover off of the phone.
Locate the battery notch and remove the battery, using either your finger or a plastic prying tool.
Use a plastic pry tool to slide both of the cards out.
Use the plastic Spudger tool to pry open the LCD ribbon cable cover.
Using a plastic pry tool, carefully pry the LCD ribbon cable from the logic board.
Take a Phillips #00 head and remove all 9 screws. Once done place them aside where you won't lose them.
Use an iFixit plastic pick to pry away the LCD from the back assembly.
Once both the LCD and back assembly come apart, look at the back assembly where the speaker is located.
Once located, take the plastic pry tool to remove the speaker from its housing and replace it with a new one.
