Samsung Galaxy Note8 Touchscreen and LCD Replacement
    • Insert a comment here
crwdns2935229:024crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0irlandacrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
ian mdx
crwdns2935283:006/30/16crwdne2935283:0
9,080 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - crwdns2934203:0crwdne2934203:0
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - crwdns2934203:0crwdne2934203:0
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - crwdns2934203:0crwdne2934203:0
Will the phone remain waterproof after this repair?
cj-dm - crwdns2934203:0crwdne2934203:0
The phone will only remain waterproof if you re-apply the correct waterproof seal, and even then I wouldn’t trust it.
Jack Donovan -
Is there a way to buy an OEM NOTE 8 front glass replacement instead of the Chinese crap on eBay?
Thanks
hakim laksiwar - crwdns2934203:0crwdne2934203:0
Just saw our question while preparing to change a Note 8 and I do not know if you received and answer. GadgetFix or Digital Supply USA(who also uses GadgetFix as a supplier) sell Samsung(original OEM) screens the cheapest so far.
Bryan Solo -
Is that copper colored piece supposed to stay on the phone after removing glass and touch screen?
Bill Stark - crwdns2934203:0crwdne2934203:0
My screen is jumping around and won’t allow me to touch or navigate my screen?
Delucious Anderson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 24,883
