Replacement de la vitre tactile et de l'écran LCD du Samsung Galaxy Note8
    • Insérer un commentaire.
crwdns2935229:025crwdne2935229:0
ian mdx
crwdns2935283:006/30/16crwdne2935283:0
9,101 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - crwdns2934203:0crwdne2934203:0
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - crwdns2934203:0crwdne2934203:0
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - crwdns2934203:0crwdne2934203:0
Will the phone remain waterproof after this repair?
cj-dm - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 24,931
