Samsung Galaxy Note5 Power Button Replacement
    1. Samsung Galaxy Note5 Power Button Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
      • Press down until the SIM Card Tray begins to protrude out of the device.
    2. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the SIM Card Tray from the slot.
    1. Samsung Galaxy Note5 Power Button Replacement, Power Button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Heat the back of the device with a heat gun for 2 minutes
    2. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
      • Be careful holding the device after heating the back, it may burn!
      • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
      • While pulling upwards, insert a pick under the rear glass
    3. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
    4. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
    5. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once all adhesive has been cut, gently lift up the rear glass to remove it.
    6. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the S-Pen from the bottom of the device
    7. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove 20 5mm screws with a Phillips #1 Screwdriver.
    8. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the back of the device and press down on the white square to remove the middle housing.
    9. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen the power button flex adhesive by holding it with the tweezers.
      • With the tweezers, pry up and remove the power button flex
    10. Samsung Galaxy Note5 Power Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push out the power button with the tip of the tweezers.
Bernice Nunez
crwdns2935283:004/19/18crwdne2935283:0
388 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S25-G17, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S25-G17, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S25G17
crwdns2935297:046crwdne2935297:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 3,696
