Samsung Galaxy Note10 Screen Replacement
crwdns2936621:0crwdne2936621:0
  1. Samsung Galaxy Note10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Test to see if phone is functional
    • Force Shut Down Device
    • Hold power button and volume down button for 7 seconds! Any longer it will restart.
    • Apply Heat to Back Glass
    • Should be to hot to touch
  2. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use suction cup on bottom 1st use metal pry tool to make enough room for guitar pick.
    • Rotate guitar pick around edges.
    • Wiggle back glass with suction cup. Use your hand to lift one edge.
    • Note10 Edges are more curved than previous note models and also curve around volume/side buttons
    • Do not recommend using metal pry tool you will most likely break it the backglass
  3. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove PH000 14 Screws
    • Start From the top removing wireless charger pad.
  4. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry from the top and slide upward to remove plastic protector
    • Remove from the top down!
  5. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fold down metal bracket of wireless charging pad
    • Disconnect Battery Connector
    • Remove Wireless charging Pad connection. (BLACK FLEX)
    • Lift upward wiggling off the side adhesive and you will pull up the bottom plastic protector
  6. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 3 PH000 Screws
    • Disconnect front camera, and 2 flexs cables marked in blue put off to the side.
    • Disconnect everything marked in Yellow or Blue
    • Sim Card Tray and Stylus should be removed as well before moving boards!
  7. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry with spudger Main Board from the top down gently lift board.
    • At an angle lift board upward with your free hand
  8. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew 3 PH000 Screws
    • With spudger lift top of charging port
    • Lift from the top of charging port moving towards the left
  9. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use heat gun warm up battery adhesive pry from the bottom up with plastic spudger
    • Lift from bottom up
    • Do not rip battery out you will deform it
  10. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place charging port daughter board in new screen assembly
    • Screw Down PH000 Screws
    • Then place the Main board
    • Connect all flex cables
    • Connect battery with adhesive and place battery to ensure it connects and seats correctly
  11. Samsung Galaxy Note10 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10 Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Connect all the flex cables
    • Place Charging pad and plastic protectors
    • Don't screw everything down complete until after you test the screen
    • Check your work place back glass with new adhesive
Mark D Schlossman
crwdns2935283:009/25/19crwdne2935283:0
6.762 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 29
